You can apply a $/kWh by using the meter billing settings. To do this:
  1. Click on the meter that you would like to set up.
  2. Click the "..." button on the right side of the dashboard header.
  3. Click the "Edit Billing Settings" option.
  4. This open the Edit Billing Settings modal.
  5. Adjust the Billing Cycle if you don't want it set to monthly.
  6. Click the box below "Billing Start Date" to pick the start date.
  7. The two boxes at the bottom allow you to set the cost per kWh. You can use the two boxes to determine the cost from a previous utility bill, or, if you know it already, simply enter the cost like the example shown below.
  8. When you are ready, click the "Save" button.
In order for a group to show $ values at least one of the meters in the group needs to have it's billing settings completed. The group will then use those same settings as the assumed settings for the rest of the meters in the group.
Once you are done setting up billing, you can then Generate Reports.
