The EKM Omnimeter II v.3 UL can meter most electrical systems commonly used in the world. It is UL and cUL Listed up to 240V, however it has Type Approval for Revenue Grade Metering up to 480V. It can operate on 50 or 60 Hz, 120 to 240 volts, 1-phase or 3-phase, it is accurate to 0.5%, and can meter up to 5000 amp systems.
Here it is on our website: Omnimeter II UL v.3
Here is the spec sheet for this meter: Omnimeter II UL v.3 Spec Sheet
This document compares our 4 Omnimeter models: Omnimeter Comparison Chart
This meter uses external Current Transformers (CTs) and will not function properly without them. These are sold separately on our website. The CTs measure the electrical current in the wires being measured. Which CTs are right for you will be determined by your type of electrical system, the maximum Amperage of your system, and the diameter of the wires being read. Solid-core CTs are less expensive but are a bit more difficult to install, they require that you disconnect or cut the wires being read and slip the CT over the wire. Split-Core CTs are more expensive but they simply clamp around the wires being read, making them much easier to install.
- Use 1 CT for single phase 2-wire systems (one hot and one neutral, with or without ground).
- Use 2 CTs for a 120/240V or 120/208V three-wire system (two hots and a neutral, with or without ground).
- Use 2 CTs for 3-phase 3-wire systems (no neutral). (UL Listed up to 240V, up to 415V is possible)
- Use 3 CTs for 3-phase 4-wire systems. (UL Listed up to 240V, up to 480V is possible)
We have CTs that can meter up to 5000 amps in stock. The CT ratio is selectable inside the meter. Here is our selection of Current Transformers.
You can read the face of the meter, or set it up to be read with your computer. The remote read is a simple RS-485, 2 wire system which can then be connected to one of our communication devices that will enable you to read your meters over the internet from anywhere in the world. Here are a couple of options:
You can wirelessly bridge the hardwired RS-485 network at any point using our 485Bee wireless mesh. This would be between multiple meters or between a meter and any of the communication converters mentioned above.
You can also view and log meter data using our free EKM Dash software (PC, Mac, Linux). Here is the Dash product page : EKM Dash
We have also assembled a number of customizable Metering Packages to help our customers determine which combination of products are right for their needs. Check out all of our Packages here: Metering Packages
How to install an Omnimeter (v.4 in this case but v.3 Omnimeters are installed in a similar way):
