The EKM-Switch120 is a normally open switch (no electricity can pass through the 120V portion of the unit). When you apply a low DC voltage to the control ports (ports 1 and 2) the switch closes and the 120 volts becomes energized.
On our website here: EKM-Switch120
Port 1 is low voltage Positive. Port 2 is low voltage Negative (or ground)
To close the switch you will apply from 3V DC to 12V DC between port 1 and port 2. To open the switch you will stop applying 12VDC between port 1 and port 2.
The Switch120 can be controlled using the relay outputs on the Omnimeter Pulse v.4 or the Omnimeter HV v.4. This tutorial explains how that can be done: https://help.ekmmetering.com/support/solutions/articles/6000075993-can-i-control-a-switch-remotely-
