The EKM Widget displays real-time and historical data from the EKM Push system. It can display electricity data, or pulse data from water or gas meters. There is no need to download any software to make the Widget work as it is a web application that operates in most current internet browsers.To see your data in the EKM Widget:
- Go Here
- Click the gear icon in the bottom right corner of the Widget
- Copy/paste your EKM Push key into the text box provided
- Click the green check mark
- Your available meters should not be available and selectable in the dropdown list.
- Select your country and timezone from the available dropdown lists
- Click Apply when you are ready
There is a lot more information about the EKM Widget here: http://www.ekmmetering.com/widget
Here is a video that explains how to set up a widget to display your own EKM Push data:
