SMART METERS:
EKM-Omnimeter HV v.4: 3 Pulse Inputs, 2 Controllable Outputs, Universal Meter, Single Phase or 3-phase, 110-600 volts, 50 or 60Hz
EKM-Omnimeter Pulse UL v.4: 3 Pulse Inputs, 2 Controllable Outputs, Universal Meter, Single Phase or 3-phase, 110-480 volts, 50 or 60Hz, UL and cUL Listed
EKM-Omnimeter Pulse v.4: 3 Pulse Inputs, 2 Controllable Outputs, Universal Meter, Single Phase or 3-phase, 110-480 volts, 50 or 60Hz
EKM-Omnimeter II v.3 UL: Universal Meter, Single Phase or 3-phase, 110-240 volts, 50 or 60Hz, UL and cUL Listed
EKM-Omnimeter I v.3: Universal Meter, Single Phase or 3-phase, 110-480 volts, 50 or 60Hz
EKM-Omnimeter HV v.5 (discontinued): 3 Pulse Inputs, 2 Controllable Outputs, Universal Meter, Single Phase or 3-phase, 110-600 volts, 50 or 60Hz
BASIC METERS:
EKM-25XDSE: Single Phase Pass Through kWh Meter, 2 or 3 Wire, 120V up to 120/240V, 100A, 60H
EKM-15E: 120 volt, 2-Wire, 18mm External CT
EKM-25IDS (discontinued): 120/240 volt Pass Through Basic Meter
EKM-15IDS (discontinued): 120 volt Pass Through Basic Meter
CURRENT TRANSFORMERS:
BCT-007-100UL: Solid Core, 7mm, 100A CT
EBCT-013-200UL: Solid Core, 13mm, 200A CT
BCT-015-200UL: Solid Core, 15mm, 200A CT
ESCT-015-200UL: Split Core, 15mm, 200A CT
EBCT-019-200UL: Solid Core, 19mm, 200A CT
PSCT-019-200: Piercing Split Core, 19mm, 200A CT
BCT-025-200UL: Solid Core, 25mm, 200A CT
SCT-025-200UL: Split Core, 25mm, 200A CT
ESCT-025-400UL: Split Core, 25mm, 400A CT
BCT-025-400UL: Solid Core, 25mm, 400A CT
SCT-032-400UL: Split Core, 32mm, 400A CT
BCT-045-600: Solid Core, 45mm, 600A CT
ESCT-055-600: Split Core, 55mm, 600A CT
SCT-065-800: Split Core, 65mm, 800A CT
BCT-080-800: Solid Core, 80mm, 800A CT
ESCT-090x050-1500UL: Split Core, 90x50mm, 1500A CT
ESCT-120x080-3000: Split Core, 120x80mm, 3000A CT
SCT-180x130-5000: Split Core, 180x130mm, 5000A CT
BCT-013-200UL (discontinued): Solid Core, 13mm, 200A CT
SCT-013-200UL (discontinued): Split Core, 13mm, 200A CT
SCT-023-400UL (discontinued): Split Core, 23mm, 400A CT
SCT-100-1500 (discontinued): Split Core, 100mm, 1500A CT
ENCLOSURES:
EKM-303015: XL UL Listed Watertight Enclosure
EKM-172711: Large UL Listed Watertight Enclosure
EKM-131808 Small UL Listed Watertight Enclosure
EKM-IENC: Indoor Enclosure
WATER METERS:
EKM-SPWM-075-CF: 3/4" Stainless Steel, Pulse Output, Water Meter
EKM-HOT-SPWM-075-CF: 3/4" Stainless Steel, Pulse Output, Hot Water Meter
EKM-HOT-SPWM-075-HD: 3/4" Stainless Steel, HD Pulse Output, Hot Water Meter
EKM-SPWM-075-HD-NSF: 3/4" Stainless Steel, NSF 61, HD Pulse Output, Water Meter
EKM-VSPWM-075-HD-NSF: 3/4" Stainless Steel, NSF 61, HD Pulse Output, Vertical Water Meter
EKM-SPWM-100-NSF: 1.0" Stainless Steel, NSF 61, Pulse Output, Water Meter
EKM-SPWM-150-NSF: 1.5" Stainless Steel, NSF 61, Pulse Output, Water Meter
EKM-SPWM-200-NSF: 2.0" Stainless Steel, NSF 61, Pulse Output, Water Meter
EKM-SPWM-100-CF (discontinued): 1.0" Stainless Steel, Pulse Output, Water Meter
EKM-SPWM-150-CF (discontinued): 1.5" Stainless Steel, Pulse Output, Water Meter
EKM-SPWM-200-CF (discontinued): 2.0" Stainless Steel, Pulse Output, Water Meter
EKM-SPWM-075 (discontinued): 3/4" Stainless Steel, Pulse Output, Water Meter
EKM-HOT-SPWM-075 (discontinued): 3/4" Stainless Steel, Pulse Output, Hot Water Meter
EKM-SPWM-075-HD (discontinued): 3/4" Stainless Steel, HD Pulse Output, Water Meter
EKM-HOT-VSPWM-075-HD (discontinued): 3/4" Stainless Steel, HD Pulse Output, Vertical Hot Water Meter
EKM-VSPWM-075-HD (discontinued): 3/4" Stainless Steel, HD Pulse Output, Vertical Water Meter
GAS METERS:
EKM-PGM-075 (discontinued): 3/4" Pulse Output Gas Meter
EKM-APGM-075-CF: 3/4" Pulse Output Aluminum Gas Meter
EKM-PGM-150-CF: 1.5" Pulse Output Gas Meter
EKM-PGM-150 (discontinued): 1.5" Pulse Output Gas Meter
REMOTE READING DEVICES:
EKM Push3: Cloud Metering System
EKM Blink: USB Converter
485Bee: Wireless Mesh Radio Node
Teltonika RUT240: Cellular Router
EKM Push2 (discontinued): Cloud Metering System
EKM-iSerial (discontinued): TCP/IP (Internet) to RS-485 Converter
PC8 (discontinued): 8 Digit Pulse Counter
IOSTACK:
EKM-ioStack: https://documents.ekmmetering.com/EKM-ioStack-Spec-Sheet.pdf
ACCESSORIES:
EKM-Fuse: EKM Inline Fuse Holder and 1A Fuse
EKM-IPC: Insulation Piercing Connector
HDR-15-12: 12V DIN Rail Mountable Power Supply
PC8 v2: 8 Digit Pulse Counter v2
EKM-Switch120: Remote Switchable 120 VAC Power Strip with 4x outlets
