EKM METERS:
EKM Metering Product Catalog PDF: Product Catalog
EKM Pricing Schedule (up to 100 units): Quantity Pricing Schedule. Contact us if you're interested in larger quantities.
EKM Metering Brochure: EKM Metering Brochure
Omnimeter, Communication Device, and Software Comparison Chart: Omnimeter, Communications, and Software Comparison Chart
Meter Values Displayed on LCD Screen: Here are the values that are displayed on the screen of the EKM Meters
Omnimeter California Type Approval: Document from the California Department of Weights and Measures certifying our entire line of EKM-Omnimeters for Revenue Grade Metering
Water Meter Comparison Chart: Water Meter Comparison Chart
NSF-61 Certification for NSF model water meters: NSF/ANSI/CAN 61 Certification
NTEP Certification for NSF model water meters: NTEP Certification
3/4" (SPWM-075) Water Meter California Type Approval: Document from the California Department of Weights and Measures certifying 3/4" and 1.0" Water Meters for Revenue Grade Metering
UL Listing: UL Certificate of Compliance for our Omnimeter II UL v.3 and Omnimeter Pulse UL v.4
Wire Diameters for each gauge: EKM Wire Sizing Chart
COMMUNICATIONS:
EKM Push: More information about the new EKM Push system
Download your copy of the EKM Dash meter reading software here: EKM Dash Information Page
EKM Dash Setup Instructions: Dash Setup
EKM Dash Information: EKM Dash User Manual
Communication Device Comparison Chart: Communication Device Comparison Chart
RS-485: Guidelines for the proper wiring of a RS-485 network
iSerial VCOM Help Sheet: Virtual COM Port Guide
iSerial VCOM Software: Download Virtual COM Port Software (Use this to discover iSerials on our network using a PC, not for reading meters)
EKM-iSerial (discontinued): TCP/IP (Internet) to RS-485 Converter
DIAGRAMS:
How EKM's various tools and websites are related to each other: EKM Organizational Diagram
Omnimeter Pulse UL v.4 + Push3:
https://documents.ekmmetering.com/Push3-Omnimeter-Pulse-UL-v4-1ph2wi.pdf
https://documents.ekmmetering.com/Push3-Omnimeter-Pulse-UL-v4-1ph2wi-no-neutral.pdf
https://documents.ekmmetering.com/Push3-Omnimeter-Pulse-UL-v4-1ph3wi.pdf
https://documents.ekmmetering.com/Push3-Omnimeter-Pulse-UL-v4-3ph3wi.pdf
https://documents.ekmmetering.com/Push3-Omnimeter-Pulse-UL-v4-3ph4wi.pdf
Omnimeter Pulse UL v.4 + Push3 + 485Bees:
https://documents.ekmmetering.com/Push3-Omnimeter-Pulse-UL-v4-485Bee-1ph2wi.pdf
https://documents.ekmmetering.com/Push3-Omnimeter-Pulse-UL-v4-485Bee-1ph2wi-no-neutral.pdf
https://documents.ekmmetering.com/Push3-Omnimeter-Pulse-UL-v4-485Bee-1ph3wi.pdf
https://documents.ekmmetering.com/Push3-Omnimeter-Pulse-UL-v4-485Bee-3ph3wi.pdf
https://documents.ekmmetering.com/Push3-Omnimeter-Pulse-UL-v4-485Bee-3ph4wi.pdf
Omnimeter Pulse UL v.4 + Push3 + 485Bees+Daisy Chain:
https://documents.ekmmetering.com/Push3-Omnimeter-Pulse-UL-v4-Daisy-Chain-485Bee-1ph2wi.pdf
https://documents.ekmmetering.com/Push3-Omnimeter-Pulse-UL-v4-Daisy-Chain-485Bee-1ph3wi.pdf
https://documents.ekmmetering.com/Push3-Omnimeter-Pulse-UL-v4-Daisy-Chain-485Bee-3ph3wi.pdf
https://documents.ekmmetering.com/Push3-Omnimeter-Pulse-UL-v4-Daisy-Chain-485Bee-3ph4wi.pdf
Omnimeter Pulse UL v.4 + Push3+Water+Gas:
https://documents.ekmmetering.com/Push3-Omnimeter-Pulse-UL-v4-1ph3wi-water-gas.pdf
Omnimeter Pulse UL v.4 + Push3 +485Bee+Water+Gas:
https://documents.ekmmetering.com/Push3-Omnimeter-Pulse-UL-v4-485Bee-1ph3wi-water-gas.pdf
Omnimeter Pulse UL v.4 + Push3+Daisy +485Bee+Water+Gas:
Omnimeter Pulse v.4 + Push3:
https://documents.ekmmetering.com/Push3-Omnimeter-Pulse-v4-1ph2wi.pdf
https://documents.ekmmetering.com/Push3-Omnimeter-Pulse-v4-1ph2wi-no-neutral.pdf
https://documents.ekmmetering.com/Push3-Omnimeter-Pulse-v4-1ph3wi.pdf
https://documents.ekmmetering.com/Push3-Omnimeter-Pulse-v4-3ph3wi.pdf
https://documents.ekmmetering.com/Push3-Omnimeter-Pulse-v4-3ph4wi.pdf
Omnimeter Pulse v.4 + Push3 + 485Bees:
https://documents.ekmmetering.com/Push3-Omnimeter-Pulse-v4-485Bee-1ph2wi.pdf
https://documents.ekmmetering.com/Push3-Omnimeter-Pulse-v4-485Bee-1ph2wi-no-neutral.pdf
https://documents.ekmmetering.com/Push3-Omnimeter-Pulse-v4-485Bee-1ph3wi.pdf
https://documents.ekmmetering.com/Push3-Omnimeter-Pulse-v4-485Bee-3ph3wi.pdf
https://documents.ekmmetering.com/Push3-Omnimeter-Pulse-v4-485Bee-3ph4wi.pdf
Omnimeter Pulse v.4 + Push3 + 485Bees+Daisy Chain:
https://documents.ekmmetering.com/Push3-Omnimeter-Pulse-v4-Daisy-Chain-485Bee-1ph2wi.pdf
https://documents.ekmmetering.com/Push3-Omnimeter-Pulse-v4-Daisy-Chain-485Bee-1ph2wi-no-neutral.pdf
https://documents.ekmmetering.com/Push3-Omnimeter-Pulse-v4-Daisy-Chain-485Bee-1ph3wi.pdf
https://documents.ekmmetering.com/Push3-Omnimeter-Pulse-v4-Daisy-Chain-485Bee-3ph3wi.pdf
https://documents.ekmmetering.com/Push3-Omnimeter-Pulse-v4-Daisy-Chain-485Bee-3ph4wi.pdf
Omnimeter Pulse v.4 + Push3 +Daisy Chain:
https://documents.ekmmetering.com/Push3-Omnimeter-Pulse-UL-v4-Daisy-Chain-1ph3wi.pdf
Omnimeter Pulse v.4 + Push3 +Daisy Chain+Water:
https://documents.ekmmetering.com/Push3-Omnimeter-Pulse-UL-v4-Daisy-Chain-1ph3wi-water.pdf
Omnimeter Pulse v.4 + Push3 +Daisy Chain+Gas:
https://documents.ekmmetering.com/Push3-Omnimeter-Pulse-UL-v4-Daisy-Chain-1ph3wi-gas.pdf
Omnimeter Pulse v.4 + Push3 +Daisy Chain+Water+Gas:
https://documents.ekmmetering.com/Push3-Omnimeter-Pulse-UL-v4-Daisy-Chain-1ph3wi-water-gas.pdf
Omnimeter II UL v.3 + Push3:
https://documents.ekmmetering.com/Push3-Omnimeter-II-UL-v3-1ph2wi.pdf
https://documents.ekmmetering.com/Push3-Omnimeter-II-UL-v3-1ph2wi-no-neutral.pdf
https://documents.ekmmetering.com/Push3-Omnimeter-II-UL-v3-1ph3wi.pdf
https://documents.ekmmetering.com/Push3-Omnimeter-II-UL-v3-3ph3wi.pdf
https://documents.ekmmetering.com/Push3-Omnimeter-II-UL-v3-3ph4wi.pdf
Omnimeter II UL v.3 + Push3 + 485Bees:
https://documents.ekmmetering.com/Push3-Omnimeter-II-UL-v3-485Bee-1ph2wi.pdf
https://documents.ekmmetering.com/Push3-Omnimeter-II-UL-v3-485Bee-1ph2wi-no-neutral.pdf
https://documents.ekmmetering.com/Push3-Omnimeter-II-UL-v3-485Bee-1ph3wi.pdf
https://documents.ekmmetering.com/Push3-Omnimeter-II-UL-v3-485Bee-3ph3wi.pdf
https://documents.ekmmetering.com/Push3-Omnimeter-II-UL-v3-485Bee-3ph4wi.pdf
Omnimeter II UL v.3 + Push3 + 485Bees+Daisy Chain:
https://documents.ekmmetering.com/Push3-Omnimeter-II-UL-v3-Daisy-Chain-485Bee-1ph2wi.pdf
https://documents.ekmmetering.com/Push3-Omnimeter-II-UL-v3-Daisy-Chain-485Bee-1ph2wi-no-neutral.pdf
https://documents.ekmmetering.com/Push3-Omnimeter-II-UL-v3-Daisy-Chain-485Bee-1ph3wi.pdf
https://documents.ekmmetering.com/Push3-Omnimeter-II-UL-v3-Daisy-Chain-485Bee-3ph3wi.pdf
https://documents.ekmmetering.com/Push3-Omnimeter-II-UL-v3-Daisy-Chain-485Bee-3ph4wi.pdf
Omnimeter I v.3 + Push3:
https://documents.ekmmetering.com/Push3-Omnimeter-I-v3-1ph2wi.pdf
https://documents.ekmmetering.com/Push3-Omnimeter-I-v3-1ph2wi-no-neutral.pdf
https://documents.ekmmetering.com/Push3-Omnimeter-I-v3-1ph3wi.pdf
https://documents.ekmmetering.com/Push3-Omnimeter-I-v3-3ph3wi.pdf
https://documents.ekmmetering.com/Push3-Omnimeter-I-v3-3ph4wi.pdf
Omnimeter I v.3 + Push3+Daisy:
https://documents.ekmmetering.com/Push3-Omnimeter-I-v3-Daisy-Chain-1ph3wi.pdf
Omnimeter I v.3 + Push3 + 485Bees:
https://documents.ekmmetering.com/Push3-Omnimeter-I-v3-485Bee-1ph2wi.pdf
https://documents.ekmmetering.com/Push3-Omnimeter-I-v3-485Bee-1ph2wi-no-neutral.pdf
https://documents.ekmmetering.com/Push3-Omnimeter-I-v3-485Bee-1ph3wi.pdf
https://documents.ekmmetering.com/Push3-Omnimeter-I-v3-485Bee-3ph3wi.pdf
https://documents.ekmmetering.com/Push3-Omnimeter-I-v3-485Bee-3ph4wi.pdf
Omnimeter I v.3 + Push3 + 485Bees+Daisy Chain:
https://documents.ekmmetering.com/Push3-Omnimeter-I-v3-Daisy-Chain-485Bee-1ph2wi.pdf
https://documents.ekmmetering.com/Push3-Omnimeter-I-v3-Daisy-Chain-485Bee-1ph2wi-no-neutral.pdf
https://documents.ekmmetering.com/Push3-Omnimeter-I-v3-Daisy-Chain-485Bee-1ph3wi.pdf
https://documents.ekmmetering.com/Push3-Omnimeter-I-v3-Daisy-Chain-485Bee-3ph3wi.pdf
https://documents.ekmmetering.com/Push3-Omnimeter-I-v3-Daisy-Chain-485Bee-3ph4wi.pdf
RV Park Wireless Plan Examples:
https://documents.ekmmetering.com/RV-Park-Wireless-Plan-Example.pdf
https://documents.ekmmetering.com/RV-Park-Wireless-Daisy-Chain-Plan-Example.pdf
https://documents.ekmmetering.com/RV-Park-Wireless-Plan-Example-1ph2wi.pdf
ioStack + Push3+Daisy +Water:
https://documents.ekmmetering.com/Push3-ioStack-Daisy-Chain-water.pdf
ioStack + Push3+Daisy +Gas:
https://documents.ekmmetering.com/Push3-ioStack-Daisy-Chain-gas.pdf
ioStack + Push3+Daisy +Water+ gas:
https://documents.ekmmetering.com/Push3-ioStack-Daisy-Chain-water-gas.pdf
ioStack + Push3 +485Bee+Water+Gas:
https://documents.ekmmetering.com/Push3-ioStack-485Bee-water-gas.pdf
ioStack + Push3+Daisy +485Bee+Water+Gas:
https://documents.ekmmetering.com/Push3-ioStack-Daisy-Chain-485Bee-water-gas.pdf
