We have made digital 3D models of some of our products and, using Sketchfab, have embedded them into this page so that you can play with them. Hopefully they are helpful! Note: These embedded 3D Widgets work best with Chrome or Firefox.
To manipulate them, first click on the Widget you wish to play with. Once it loads you can rotate it by clicking and dragging. Right click(also control click on a Mac) and drag to zoom. Hold Shift + click and drag to pan up/down or left/right. Also, after you have clicked on a Widget, you can click the "?" at the bottom for more information on how to manipulate the models.
Omnimeter I v.3 -without terminal block covers by EKM Metering Inc. on Sketchfab
Omnimeter I V.3 - 120 Volt Single Phase Setup by EKM Metering Inc. on Sketchfab
Omnimeter I v.3 - 120/240V Single Phase Setup by EKM Metering Inc. on Sketchfab
Omnimeter I 3-phase 3-wire for Sketchlab.dae by EKM Metering Inc. on Sketchfab
Omnimeter I v.3 - 3-phase 4-wire Setup by EKM Metering Inc. on Sketchfab
Water Meter.dae by EKM Metering Inc. on Sketchfab
Gas Meter - Remote Readable Pulse-Output by EKM Metering Inc. on Sketchfab
Omnimeter UL v.3 - EKM Push Communications by EKM Metering Inc. on Sketchfab
Omnimeter Pulse v.4 -Wired to Water & Gas Meters by EKM Metering Inc. on Sketchfab
