- Setup a widget as you would like it to display by default
- Click the gear icon towards the lower right of the graph.
- Copy the iframe html code at the bottom of the settings window.
- Paste this iframe into the html of the webpage where you want the Widget to appear.
Here is an example of the iframe code:
<p> <iframe src="http://widget.ekmmetering.com/EKM2/?reads=500&key=MTAxMDoyMDIw&meter=10068&scale=realtime&bar_graph_field=kwh_tot&total_field=kwh_tot&kwh_tot_cost=.15&kwh_currency=USD&timezone=America~Los_Angeles&historical=Green" frameborder="0" width="100%" height="620"> </p>
