To visualize you pulse count data from your water or gas meter:
- Click the "History" button to display the bar chart for the Omnimeter Pulse v.4 that is connect to your water or gas meter.
- Click the gear icon towards the lower right of the graph.
- Click the "Pulse/kWh" tab at the top of the settings window.
- Click the secondary tab for the pulse input that you want to setup. i.e. "Pulse 1"
- First enter the value of the pulse. For example, the value of the pulses from our water meters is typically 0.1 cubic feet per pulse.
- If you would like to also see the monetary value of the water or gas usage, you can enter a cost/unit of measurement. You can determine this by referring to you utility bills.
- You can also name the pulse input if you wish.
- If you would like to convert the unit of measurement to a different unit, select the "Converted Value" unit from the drop-down list at the bottom of the settings window.
- Now click the "Layout/Fields" tab at the top of the Widget.
- Click the "Total Field" drop-down menu and select the pulse value that you want to visualize. i.e. PC 1 Value or PC 1 Value Converted.
- Click the "Bar Graph Field" drop-down menu and select the same value as in the previous step.
- If you would like to change the color of the bar graph you can do that from the drop-down list provided.
- Click "Apply" when you are ready.
