Widgets can now be repositioned on any dashboard.
To do so:
  1. Go to the dashboard that you would like to rearrange.
  2. Click the "Reorder" toggle button at the top right of the dashboard, under the gear button.
  3. Once the toggle is switched the widgets will shrink and allow you to move them around the dashboard.
  4. Click and drag the widgets you want to move
  5. Position the widgets and drop them where you like
  6. When you're finished, click the toggle button again to return to regular use of the dashboard.
*To delete a widget, click the Edit button in the top right corner of the widget and then click the 'Delete widget' link.
