The EKM Push data service is free for meters that are set to a once/minute read rate (this is the default) or slower. If you’d like to have your meter(s) read faster it is possible to read meters as fast as once/second. For faster that once/minute read rates there is a per-meter monthly fee that varies depending on the rate, which you can see in the drop down list below.
Please note that a once/second read rate is only possible if you you have a single Omnimeter connected to your EKM Push gateway. It takes approximately one second to read a meter and only one meter can be read at a time by a given gateway. So for example, if you have 50 Omnimeters connected to a Push gateway, the fastest that you will be able to read each of those meters is once every 50 seconds.
You can subscript to increase your meter read rate by going here: https://www.ekmmetering.com/pages/subscription
Changing the read rate is done manually by our team at EKM so please allow for up to one business day for the read rate change to take affect.
