TABLE OF CONTENTS
- Connection Instructions
 - Omnimeter I v.3 Diagram
 - Omnimeter II UL v.3 Diagram
 - Omnimeter Pulse v.4 Diagram
 - Omnimeter Pulse UL v.4 Diagram
2-wire systems can occasionally be 240 volts (Hot to Hot). Metering of these systems can be done with any of our Omnimeter models
- Do I want to read the meter(s) locally with computer or do I want a cloud based solution (EKM Push).
 - What diameter and amperage rating will I need for the Current Transformers? You will need one CT for your 2-wire single phase electrical system.
 - Do I need to go wireless?
 - Do I have a need to daisy chain multiple Omnimeters together? This allows you to connect multiple Omnimeters in series, which can then be connected to a single communication device.
Connection Instructions:
For a 240 volt 2-wire system (2 Hots, no neutral) you will only need to use 1 CT. When you measure the voltage between these 2 wires you will get 240 volts.
- Turn off power to the sub-panel.
 - Connect the L1 line voltage reference wire to port 7 on the Omnimeter
 - Connect the L2 line voltage reference wire to port 10 on the Omnimeter.
 - Connect the CT so that L1 passes through it and the arrow on the CT points towards the load.
 - Connect the CT black wire to port 1 on the Omnimeter and the CT white wire to port 2 on the Omnimeter.
This video tutorial provides an example of how to install an Omnimeter Pulse v.4 on a 120/240v electrical system. You can use this video to infer how a single phase, two wire installation might go. The only absolute difference is that there will only be one CT and one voltage reference wire:
Below are diagrams showing each Omnimeter model wired to a single-phase 2-wire no-neutral electrical system, while also being RS-485 hardwired to a Push3 gateway (A to A, B to B).
Omnimeter I v.3:
Omnimeter II UL v.3:
Omnimeter Pulse v.4:
Omnimeter Pulse UL v.4:
See this model for reference of how to properly connect an Omnimeter to a 2-wire system:
Here is a link to a movable 3D model of the above diagram that you can use to see details of any side: 2-wire Single Phase EKM Omnimeter 3D Model
