The ioStack supports 0-3.3 volt DC Analog, 1-Wire, and I2C sensors.
Some example of what these can be are:
- In Tank Level Pressure sensors
- Plumbed in Water pressure sensors
- Air Pressure sensors
- Air Pressure Differential sensors
- Light sensors
- Thermocouple sensors
- Vibration sensors
- Weight sensors
- Humidity sensors
- Solar Radiation sensors
- DC Voltage sensors
- DC Current sensors
- Tilt sensors
- Oil Pressure sensors
- Soil Moisture sensors
- Position sensors
- Distance sensors
- RGB Color sensors
- Noise Decible sensors
Most sensors will need to be sourced from a 3rd party. You can see our limited sensor offering here: https://www.ekmmetering.com/collections/sensors
