Yes! We have Pulse-Output Water Meters that have a pulse output that can be read remotely. For each unit of water that flows by the meter produces an electrical pulse that can be measured from a distance. The total water use can always be read on the face of the meter as well - as a standalone device.
Please refer to your water meter's spec sheet for how its pulse output should be wired. A printed copy is included with the meter but you can also download a copy here: https://help.ekmmetering.com/support/solutions/articles/6000068435-spec-sheets
Here is an example drawing of water meters connected to v.4 Omnimeters. The Omnimeters are daisy chained to a Push3 gateway in order to make the meters readable online:
Here is an example drawing of water meters connected to ioStacks. The ioStacks are daisy chained to a Push3 gateway in order to make the meters readable remotely online:
If you need to go short range wireless, you can wirelessly bridge the hardwired RS-485 network at any point using our 485Bee wireless mesh.
If you're using a v.4 Omnimeter and the EKM Push system to read your water meter(s), then you can use Encompass.io to read your water meter data. This is our free online platform for visualizing data, generating reports, and billing.
Alternatively, if you don not have an internet connection available, you could have a computer running on site with the Dash software running on it in order to log data locally. You could connect the Omnimeter Pulse v.4 to this computer via the iSerial (discontinued) or our $25 USB Converter. You could set the Dash software to email you monthly or daily, etc., reports of your usage.
Take a look at our customizable Metering Package for remote reading electricity, water and/or gas here: Remote Water, Gas, and Electricity Metering Package
The image below shows the wired connections that are necessary for remote water metering. In reality these wired connections will be extended over further distances (up to 10,000 feet for the pulse output wires coming from the water meter, up to 4,000 feet for the RS-485 wires going to the EKM Push gateway). Keep in mind that up to 3 water meters can be connected to each v.4 Omnimeter.
