Yes! We have Pulse-Output Gas Meters that have a pulse output that can be read remotely. For each unit of gas that flows through the meter, it produces an electrical pulse that can be measured from a distance. The total gas usage can always be read on the face of the meters as well - as standalone devices.
Please refer to your gas meter's spec sheet for how its pulse output should be wired. A printed copy is included with the meter but you can also download a copy here: https://help.ekmmetering.com/support/solutions/articles/6000068435-spec-sheets
Here is an example drawing of gas meters connected to v.4 Omnimeters. The Omnimeters are daisy chained to a Push3 gateway in order to make the meters readable online:
Here is an example drawing of gas meters connected to ioStacks. The ioStacks are daisy chained to a Push3 gateway in order to make the meters readable remotely online:
If you need to go short range wireless, you can wirelessly bridge the hardwired RS-485 network at any point using our 485Bee wireless mesh.
If you're using a v.4 Omnimeter and the EKM Push system to read your gas meter(s), then you can use Encompass.io to read your gas meter data. This is our free online platform for visualizing data, generating reports, and billing.
Encompass.io makes use of the the EKM Push data and makes your gas meter data available online in your own secure account. The web application lets you visualize your gas usage in a variety of graphs and it also allows you to generate reports. These can be used to bill your tenants or simply as a way to monitor your gas usage over time. Encompass is free for all EKM Push users so there is no risk if you want to try it out.
We also have our EKM Dash software that will let you log the meter usage to your computer. This software does not have any monthly fees and can be used on an unlimited number of meters. You can set it up to make a monthly report on any day of the month. The software can automatically generate a report and email it to you, or your tenant/user. Our software has the ability to respond to events configured by the user. You could set it up to email you, for instance, when a certain usage amount has been reached. This is in the Triggers page of the Dash software, under Events.
Alternatively, if you don not have an internet connection available, you could have a computer running on site with the Dash software running on it in order to log data locally. You could connect the Omnimeter Pulse v.4 to this computer via the iSerial (discontinued) or our $50 USB Converter. You could set the Dash software to email you monthly or daily, etc., reports of your usage.
Take a look at our customizable Metering Package for remote reading electricity, water and/or gas here: Remote Water, Gas, and Electricity Metering Package
The image below shows the wired connections that are necessary for remote water metering (water meter pulse outputs are connected in the same way as gas meters). In reality these wired connections will be extended over further distances (up to 10,000 feet for the pulse output wires coming from the gas meter, up to 4,000 feet for the RS-485 wires going to the EKM Push gateway). Keep in mind that up to 3 gas meters or water meters can be connected to each v.4 Omnimeter.
